Sähköjä veneessä
mauri
Sähköjä veneessä
Viesti Kirjoittaja mauri » 25 Marras 2005 16:31
Löytyipä erään akkufirman sivuilta oheinen lista esiintulleista kysymyksistä. Eihän kunnon puuveneilijät noin tee, eihän...
Magic moments....on the 'phone..................or why " technician Bruce gets Surly..."©
11. I've used that DF25 for a year and a bit. Should I recharge it yet?
10. ..but the boat was only submerged overnight..
9. So me drilling a hole in the battery ain't covered by the warranty ? ..
8. The fire? Oh, I got tired of the fuse blowing and jammed in a nail instead....
7. Well, I did the hook the battery backwards at first, but only for a few minutes.
6. I wound up the regulator to 17v for a really fast charge....
5. The batteries were way low so I plugged the charger into the inverter.....
4. I heard that dry batteries are maintenance free, so I emptied the water out.
3. Breaker panel? Naw,  I managed to jam all fourteen connectors onto the battery posts...
2. I figured I'd just plug it in to the 230 outlet and worry about the input selector switch later..
1. You mean I can't change the Alternator belt without stopping the engine?
