Difference between RST and haponkestävä A4
rod1e
Viesti Kirjoittaja rod1e » 04 Joulu 2013 16:25
Hello, it's been many years since I've been here...
Can someone tell me the difference between RST fixings, screws and things. ... and ones that are marked haponkestävä A4?
I know that A2 class is registered as not suitable for seawater and A4 is OK. But what is RST?
Any help would be much appreciated.
Cheers
rod
mtuitto
Re: Difference between RST and haponkestävä A4
Viesti Kirjoittaja mtuitto » 04 Joulu 2013 18:51
RST is same that A2. RST is "ruostumatonteräs" in finnish.
-mikko-
VilleS
Viesti Kirjoittaja VilleS » 04 Joulu 2013 21:42
This might be usefull... You can find it all here .
http://en.m.wikipedia.org/wiki/SAE_steel_grades" onclick="window.open(this.href);return false;
rod1e
Viesti Kirjoittaja rod1e » 04 Joulu 2013 23:05
Thanks guys... that's helped me work things out...
So RST just means standard Rosteri: A2 or EN 304 or 18/8
and marine grade stainless is A4 or EN 316(L) or 18/10 (surgical steel?)
Was just looking at different screws... also very confusing...
Kestopuuruuvi, Terassiruuvi, Yleisruuvi, Levyruuvi, etc
Do you think the A2 grade is OK for planks in a boat or should I make sure everything is A4 grade?
Cheers
Rod
Lampila
Viesti Kirjoittaja Lampila » 05 Joulu 2013 10:06
I have been using A2 in some internal or interior parts of a boat but not in those parts of a hull that are contacted with the water all the time. Are you making a total new boat or repairing old one? If new one then i would say definitely A4.
Viimeksi muokannut Lampila, 05 Joulu 2013 10:09. Yhteensä muokattu 1 kertaa.
- Pohjalla on paremmin -
VilleS
Viesti Kirjoittaja VilleS » 05 Joulu 2013 10:08
It might be reasonable to use grade A4 everywhere, but you should use only A4 grade below seawaterline and you can use A2 above. You can also use bronze wood screws, those you can use in anyplace (high seawater resistant) .
http://www.toplicht.de/en/shop/bootsbau ... e-senkkopf" onclick="window.open(this.href);return false;
rod1e
Viesti Kirjoittaja rod1e » 05 Joulu 2013 10:37
OK, thanks for the advice.
I'll use A4 throughout.
It's a new boat, small sailing dinghy...
Cheers
Rod
